Project won't open
Hello, Your file seems to be damaged due to virtual memory error. Unfortunately, you have to continue from your last save. In order to prevent such situations, we strongly recommend working with backups, you should not work on a single file all the time, but by saving different file names by using the save as option. Or you should use the backup option of the program while recording.
Hello, take it easy, a project I made is not opening after my last save. It keeps kicking from the program while it will open. Can you help me, please.
"dago46":1gqlr86z" said:
Hello, a project I made does not open after my last save. It keeps crashing from the program when it is opening, can you please help me please.
Hello, "Backup while saving (*.bak)" in the general settings dialog If the option is checked, backup files with *bak extension are created under the same folder as your project. Select the file type *.bak in the load project dialog and try to open these files. If you add the unopened project file, we can examine it. Good work
"Levent Özpak":2haz6d0u" said:
"dago46":2haz6d0u" said:
Hi, take it easy, A project I made is not opening after my last save. It keeps crashing from the program while it will open. Could you please help? In the load project dialog, select the file type *.bak and try to open these files. If you add the project file that is not opened, we can review it. Good work
First of all, thank you. But I was working with the "bak" file closed, unfortunately I had a lot of trouble because of it, I couldn't do anything anyway. Can you give me your e-mail address, do you mind if I send you an e-mail?
"dago46":265utnzk" said:
First of all, thank you. But I was working with the ''bak'' file closed, unfortunately I had a lot of trouble because of it, I couldn't do anything anyway. ] If the file size is large, you can upload it to a site such as
etc. If you are our 10 version licensed user, you can become a member of the portal and upload your project here.
"Levent Özpak":12qasgpz" said:
"dago46":12qasgpz" said:
First of all, thank you. But I was working with the "bak" file closed, unfortunately I had a lot of trouble because of it, I couldn't do anything anyway. Would you mind if I send you an e-mail, please?
etc. You can upload it to a site and give the link. If you are our 10 version licensed user, you can become a member of the portal and upload your project here.
