Project orientation has changed how do I rotate the whole structure
gencideci
The direction of a project I finished has changed. It doesn't come out by mirroring because it didn't fully rotate. When I rotate the model with the rotate command, the plate tile is broken. beams collide. Do I have to model from scratch, what should I do?
Re: The direction of the project has changed help???
"gencideci":3l72bafn" said:
The direction of a project I finished has changed. It is not mirrored because it does not rotate completely. When I rotate the model with the Rotate command, the plate floor is broken. I need to model from scratch, what should I do?
You can use the "Rotate Structure" command in the Classic menu under the Change menu, under the Reinforcing tab in the ribbon menu, under the Modify section.
