sezeraynur
Hello. First of all, have a good day. I am asked to make static and reinforced concrete controls of the buildings to be built. As a person who has not used a package program before, the last project I received was prepared in idecad, I have a few questions for you. I am a person who defends to the end the necessary care in the design of reinforced concrete and reinforced concrete. Thank you very much for your support in advance. QUESTIONS 1.This project was solved by assuming full rigid diaphragm and only B3 earthquake irregularity emerged, and as far as I can see in the reports, ide met the allowable condition (50% internal force increase) in TDY2007. There is no problem here. If a solution is made with the acceptance of a semi-rigid diaphragm, 39 errors appear in the reports. Now in this case, do I want a zero-defect report in both solutions or can I only accept a fully rigid or semi-rigid solution, how safe is it? 2.Is there an effect on the rigidity behavior of the floors in which hollow hollow floor tiles are used throughout the building? (Select semi-rigid vs. fully rigid?) 3. Should all geometry controls be provided, for example, walls that do not meet the requirements of TDY2007 in TDY2007 were used, that is, they should be rearranged as columns; As a result, the curtain behavior and column behavior will be different, assuming that the program will solve it, how effective is this in the solution, does it cause big errors or is it within acceptable limits? 4. At some points, there are gaps in the column-beam junctions, what does this mean, what is the effect? 5. Does the analysis made in an original idea give different results in the demo? 6. Finally, this ide data was made in 7 versions, and when you analyze the same data in demo 8 versions, the errors are much more; Is it an error caused by the version difference or does idecad8 demo perform much better analysis than version 7. I sent the project file to destek@ideyapi.com.tr
