Program terminates during analysis
Gokhan30
Hello. I am getting a program termination error during the analysis. I analyzed this system and I did not get any error like termination. I wanted to rest a little and continue the project like that. After 1 hour, I wanted to analyze when I opened the program again, but it gave an error and closed. I couldn't perform my analysis. I got the following errors in the analysis I was able to do: Relative floor drift high error. Using the information I read from the forum, I reduced this error to 0.0081, but I could not manage to stay on the safe side. Also, when I check the geometry, I get the error that the beam - slab edge overlaps. I could not resolve this error when I deleted and defined the beam again. Even though I deleted the tile in the same way and did it again, I kept getting this error. Could you please review my project if you can fix the program termination error. Thank you very much in advance
I found my mistake. My raft foundation was deleted. That's why I was getting an error. I was able to analyze when I corrected it. Now I cannot upload the project here again. .
Hello, one of the projects you sent does not open as an old version. There is a relative floor offset error of 0.0083. Thank you for your attention anyway.
I installed it with 8.062 in case you may not have V10.16. Open V10.14, get RX=Ry=8 and A11 from the wizard and have it analyzed, it doesn't give an error. Unver ÖZCAN
