Program shuts down in analysis
Hello, I can also get analysis results. My suggestions; --I also do not recommend you to solve this building, which has a span of 10.45 m from column to column, with beams of --40 cm height, --With 25/40 beams (10.45 m) on which the ladder is loaded, --Change your static system. Unver ÖZCAN
- I tried 2 times, it was closing - now I tried again, it did not close. I will forward your interesting suggestions to the author, I will ask another question, is my pool modeling correct?
"mkrts88":3k7u0v0s" said:
- .....I will forward your suggestions to the author I will ask one more question, is my pool modeling correct?
Hello, In order to solve the pool curtains and the foundation together, a superstructure interactive solution should be made in the project. Also; -Some of the columns S04 and S12 do not fit on the raft foundation. I suggest you change the position or dimensions of the pool. -Define the sides of the foundation at zero level and the foundation under the pool separately. -Define the upper elevation of the pool curtains as -390 cm. Good work
