Program shutdown
sabit
IN SEMI-RIGGED DIAPHRAGM PROJECTS, THE PROGRAM CLOSES ITSELF TOO FAST. EVEN IN A SIMPLE 5 FLOOR PROJECT, THIS HAS HAPPENED TOO MUCH AND IT'S VERY ANGRY. WE HAVE TALKED ABOUT THIS BEFORE FRIENDS FROM SUPPORT BUT NOTHING HAS CHANGED EMERGENCY SOLUTION... :( 2. FOR EXAMPLE, AFTER 60/30 BEAM INSTALLED, THE FAILURE IS LOWER THEN THERE IS 40/30 DIMENSIONS. THE VERSION DID NOT HAVE THIS PROBLEM AND IT IS VERY ANGRY 3. WHY IS THE TAB KEY FROM THE KEYBOARD WHEN I ENTER THE DIMENSIONS OF THE COLUMN AND BEAM?
Please add the project that you have experienced a program shutdown, which you say is very simple. Let's examine the project and find an immediate solution.
