Program Closing
civilng
While analyzing the project and examining the reports, the project closes by itself or after correcting the errors that emerged as a result of the analysis, the program gives an error when I want to analyze again. The project is attached.
Hello, The problem you mentioned could not be created by us. Can you contact the phone and have the steps that cause the program to close? Note: In the project, the beams and floors in the area between the 3-9 axes and the CD axes on the basement floor are given a positive level. However, no elevation was given to the columns to which the beams are attached. It should be shortened by giving an upper level to the relevant columns in the basement and by giving an upper level to the next. Good work
"civilng":zflg6gz8" said:
While analyzing the project and examining the reports, the project closes by itself or after correcting the errors in the analysis, the program gives an error when I want to analyze again. The project is attached.
Hello If you check the geometry, it's on the 1st basement floor There are "Wrong Beam Level" problems. I did not have any closure problems in the current version of your project. I have brought the upper levels of the column around the landing in the 1st basement floor to the beam level. I have adjusted the elevations of the relevant columns for the continuity of the columns on the ground floor. If the shutdown situation repeats for you, you need to describe the situation step by step or we can look at your computer remotely.
"muhammed47":d3m09sjs" said:
I get a warning that there is a beam elevation error in the attached project. I need to change the elevation of the beams with an error due to the stairs. I would appreciate it if you could help me
You gave the beams +160 elevation. The point where the beams are defined is the ceiling of the floor. It goes up and stays in the space. The columns are defined from the floor to the ceiling of the floor. Therefore, they are not connected to the column on that floor. If you give the elevation of your beams instead of +160 (-160), you will not have a problem. Thus, your beam will remain in the floor and connected to the column. You can adjust the other floors in this way at the bottom and you can also data the top floors according to your design.Note: If you wish, you can also make an arrangement by playing with the elevations of the columns.In the column dialog, top level: is how much the upper end of the column on the floor ceiling goes up or down.(+,-) If the elevation is how much the lower end of the column at the floor of the floor goes up or down. ,-)
