"saridurmus":24azn483" said:You put another curtain under the P025 and P026 curtains in the Basement Floor, so the program closes. Check the geometry and you'll see. When it's deleted, it analyzes. I brought the existing curtains in the elevator pit to -150 and defined 150 curtains on the facades without curtains. The same problem continued again. I don't understand how you can analyze without any problems. I wonder if it is due to the PC?
I wonder if you have done anything. When I download it from your link, there is no problem."saridurmus":1yfk9mau" said:I have no problem.Here's the linkYou do not have permission to view link Log in or register now.
thank you. good luck to you"saridurmus":2oi6crm6" said:you put curtains on top of each other on the basement floor, I deleted it, and besides that, I fixed the basement curtain's jeans, that's all.
Shouldn't we have lowered the basement curtain down to the elevator raft?"saridurmus":3k0wuico" said:you put curtains on top of each other on the basement floor, I deleted it, and I just fixed the elevation of the basement curtain, that's all.
Hello, -The analysis problem in the project is due to the fact that the P158 and P160 curtains are given a negative upper level equal to the storey height. If the elevations are arranged as -310 cm instead of -330 cm, analysis will be made in the project. Apart from that, curtains are defined on top of each other with the same coordinates as P024 and P025 curtains. - In the program, we recommend modeling the elevator shaft as flat without raising the curtains and raft foundation, and giving the elevator shaft detail separately. url]http://www.idecadsupport.com/forum/viewtopic.php?f=5&t=4426&p=20094&hilit=asans%C3%B6r&sid=60698590c1e1fcf54802a63d4bbff15f#p20094[/url]"hkaragoz":1rokhhfo" said:hello. The program throws itself while doing the analysis. If there is no gap in the building with the elevator pit, there is no problem if there is no space. I have not encountered such a problem in my previous studies. I would appreciate it if you could help. The link is below. good work... [url =https://we.tl/fVrohLOrNE]https://we.tl/fVrohLOrNE[/url]
"erşahinler":1fs1v3zu" said:when I analyze the scaffolding drawing, the program closes after analyzing up to a certain part. I don't understand why my work is like this all the time. You can assign material in the Slab/Static tab by entering its properties.You should do this for all scaffolds in the project.
Redefine the D105 slab at -22 cm level on normal floors. Analysis will be possible in the project. Some notes: -The 2nd basement floor is rigid in your project. Analysis Settings/General Settings I suggest you select "bi-load state calculation method" for "4.8.5 modal calculation methods and calculation of basement buildings" in tab"mertçıngı":2tgj5iaj" said:closes during analysis
