Program closes during export
Gokhan30
Hello, I need to send a mold plan to the architect, but the program ends and closes during export. What could be the reason for this. I would be very happy if you could help. Since the size is large, I leave the link here. Thank you very much in advance. Also, Happy Civil Engineers Day :)
Hello there; You have an empty layout in your project, you can remove the layout option while exporting, or you can delete the layout and export it. Note: Your coordinate values in the wizard appear as default values in your project. Since you do not have curtains in both directions in the building, it would be appropriate to choose the R coefficient A11. Fix errors in geometry control. There is a vertical continuity problem in your columns, I suggest you define your column nodal points at the axis intersections to eliminate this.
