Some determinations and suggestions: 1- In the attached file, there is angle dimensioning in the normal floor formwork plan. When I select all (ctrl + A) and Copy (ctrl + c), the program breaks. The same problem does not occur when I delete the angle dimensioning. I tried to select and copy an angle measure in an empty project, no problem. (The same problem was encountered when entering the cloning command other than the ctrl + C command)
Log in or register now.
2- Again, there is angle dimensioning in the normal floor formwork plan in the attached file. Move this dimension and its objects. Dimensions are broken. 3- Stair drawings / drawing properties / layout / scale is 1/50 although it says 1/20. In the title text under the sheet, it says ".... drawings Ö:1/50". 4- Enter the Node Move / Select Node / Zoom command. The selected nodes are gone and exiting the command. 5- Why is the 0.0 node not captured even though the DN capture icon is active and the lock to the D. Point is turned on in the settings? 6- The dimensions of the dimension text in the cross section in the mold plan are very small. Cannot be changed. (is it?) 7- Let's add a "close" button to the geometry control dialog. Also: I created my own template file. But when I was creating this I wanted to use the settings from a project I was working on. I made all the settings and deleted the objects. There were also extra layers, so I used the "delete empty layers" command to delete them as well. The layers used by the program itself were also deleted. Now when I open a project with my file, it comes with standard and sketch layer. There is no problem while working. I thought that while creating the axle, the axle layer is formed. But neither the axle nor my other layers have come back. What is the way to this? (without repeating) Best regards..... NY.
