Program break in block file
NYILMAZ
The attached zip file contains a block file. I selected all objects on a floor in a project. I said copy to file and made a block. Then when I said paste from the file, the program broke. I tried to call it into a new project and the same situation happened again. I tried the same thing for another floor, same thing happens again. I don't know which object is caused by incorrect blocking. Maybe try one by one. All columns or all beams or, I don't know, other elements can be blocked one by one, but I did not examine them. I present it to your information. If you find that it is caused by an object or object type, indicate it and I will block it without selecting that object. Good luck with.
"NYILMAZ":2p7kojv8" said:
The attached zip file contains a block file. I selected all the objects on one floor in a project. I said copy to the file and made a block. Then when I tried to paste from the file, the program broke. I wanted to call it into a new project, the same situation again It happened. I tried the same thing for another floor, and the same thing happens again. I don't know which object is caused by incorrect blocking. Maybe it can be tried one by one. All columns or all beams or I don't know other elements can be blocked one by one, but I did not examine them. I would like to inform you. Or if you find that it is due to the object type, let me know and I will block it without selecting that object. Take it easy.
Hello Nedim, I congratulate you for reporting the error as an example and thank you very much.
"NYILMAZ":2b14deq7" said:
The attached zip file contains a block file. I selected all the objects on one floor in a project. I said copy to file and made a block. Then when I tried to paste from the file, the program broke. I wanted to call it into a new project. Same situation again It happened. I tried the same thing for another floor, and the same thing happens again. I don't know which object is caused by incorrect blocking. Maybe it can be tried one by one. All columns or all beams or I don't know other elements can be blocked one by one, but I did not examine them. I would like to inform you. or if you find it is due to the object type, let me know and I'll just block it without selecting that object. Take it easy.
Hello, If you uncheck the preview line on the right before selecting the block file while applying the paste from file operation, you can paste the file. Would you give it a try? Thank you for your report.
I was curious about the situation that Nedim said, I tried a small 4-storey building with one apartment with all the elements including the stairs, I selected all but the foundation from the 3d window, copied it to the file, when I opened a new project page and said copy from the file, when I selected the material mismatch warning, I selected use all available, the base point After the prompt, the file was pasted.! However, only the ground floor of the 4-storey building was completed. version 7.014 operating system win7 64 bit 2-3 years old laptop pc
Since I was very busy today, I was able to check the messages now. In this context:
"Ismail Hakki Besler":3rb0vqys" said:
Hello Nedim , I congratulate you for reporting this error as an example and thank you very much.
Thank you. Since I know your structure, I am trying to contribute to this. Anyway...
"Levent Özpak":3rb0vqys" said:
Hello, If you uncheck the preview line on the right before selecting the block file, you can paste the file. Would you give it a try? Thanks for your report.
When I tried as you said, the problem was solved. But this time I ran into a problem. In a 6-storey project, I imported the basement as a block, I made the ground and a normal floor in the same way. (My aim was to move the project to 0.00; 0.00 so that the axis distance would be written correctly while doing all these operations). The process I did in between was the contour calculation process. then I made a layer copy from the 1st regular floor to the 2nd, 3rd and 4th normal floors. I pressed the column reinforcements icon without making any calculations. The program closed after freezing for a while. He did not do the same in the beam and panel reinforcements command. It only occurred in column reinforcements . I repeated several times, same result. The file size is too large, I will try to upload it and give the link or send an e-mail. But I want to make one point. I tried a similar scenario on the look of the same file before saving, but I could not reproduce the problem, it worked without any problems.
By the way, all beams appear as unsupported beams in geometry control. I couldn't make any sense. This could possibly be the reason, but I don't know why this happened. However, I did not go to any fix so that the problem could be found. Also, this is how I made an account. There were no geometry errors in the beams and when I clicked on the column reinforcements, no break in the program occurred. Take it easy, good night, I'm tired now and I'm going to bed. ;)
Hello Nedim, the problem is solved when you enter the properties of any beam element in the project and click OK. It is also important to be able to do this kind of problem from the beginning within a scenario (as it is fixed when you calculate). I haven't been able to create the problem exactly in my experiments, but we take your project into our notes for review. Good work...
"NYILMAZ":2bmp17zo" said:
By the way, in the geometry control all beams appear as unsupported beams. I can't make sense of it. It's probably the reason but I don't know why it happened. However, I didn't make any corrections so that the problem could be found. Also like this I made the calculation. There were no geometry errors in the beams and there was no break in the program when I clicked on the column reinforcements. Good night, I'm tired and I'm going to bed now. ;)
Hello, the project that you opened in ideCAD Static and checked the geometry was previously drawn in ideCAD Architecture? If you have opened the ideCAD Architectural project, it is enough to analyze as Hakan Bey wrote before checking the geometry.
"YasinTezel":ufesvrnx" said:
Hello, the project that you opened in ideCAD Statik and checked geometry was previously drawn in ideCAD Architecture project? First, we tried to draw it in statics and dress it in architecture. But since the project went through many phases, there were operations to save as, architectural objects with blocks or import static objects. Of course, when the column reinforcements were pressed without calculation in the reshaped project, the situation I mentioned arose. When I looked at the control, I saw the problem of bareless beams In such cases, I immediately take a backup without much confusion and save it for the scenario (to be able to recreate) I sent it to you after all. I say take it easy, I wish everyone a nice, prosperous and trouble-free week before you.
