thank you. Also, should the steel grade be taken as s420 or bç1 should be taken as s220 in the current situation performance, such as steel ribs in some of the stripped columns and beams, and a flat but ribbed reinforcement ratio in some of them. Can a performance analysis be taken without evaluating the system? Are the reinforcements entered into the program one by one for the current situation? Can I see the reinforcements of all columns, beams, curtains, and foundations in the current status report? My last question is 50% (HK) in 50 years according to the earthquake regulation, since the building is a sports facility; They are expected to provide 10% (CG) performance levels in 50 years. When I examined some static reports that I could download from the internet, while analyzing, for some structures, the structural importance coefficient was taken as I=1 AND I=1.5, or for some, the design spectrum multiplier was 1 in the existing HK and reinforcement HK performance report. I found that it gets a design spectrum multiplier of 1.5 in the current CG and retrofit CG performance report, where it gets .0. What coefficients should be taken according to the existing and strengthened situation as the design spectrum multiplier for the sports facility. Thank you.
