Problem with installing ideCAD Static 7.017 Demox64
gavra1
ideCAD Static 7.017 Demo 64 bit (Turkish).exe file
and installed it on Windows 7 64 bit operating system. However, I got the error "The application failed to start properly (0xc000007b). Click OK to terminate the application.". What would you suggest to do to be able to use the program as a demo? Thank you for your interest.
and installed it on Windows 7 64 bit operating system, but "Application failed to start properly (0xc000007b). Click the OK button to end the application. I encountered the error. 220 67 17
likewise, I can't open 7.17 7.18 with hasp 5.511 no problem, it opens without any problem. If the problem was solved, if 2 lines of text were written, we wouldn't have to bother you again, Mr. Hakan.
"HakanŞahin":pxf0q9jk" said:
Hi, If you call us from our Bursa office during working hours, we can look into your problem with remote access 0 224 220 67 17
"professional":pxf0q9jk" said:
I can't open hasp 7.17 7.18 5.511 no problems, it opens without problems. If the problem was solved, if we wrote 2 lines of text, we wouldn't have to bother you again, Mr. Hakan, with my best regards.
Since we were not called by phone, we could not look into the matter remotely. For your problem, you will not cause any discomfort, as long as we can help. Good work
