Problem with balcony definition
cihanonarici
Have a nice day. As far as I understand, the definitions of the type of balcony I have sent cannot be defined without dividing the beams yet, it is stated in the program's book that I need to use the divide by intersection option, but this icon cannot be selected in the slab description toolbar because it is inactive, so I have to manually divide the beams and then fit the system, at least that's what happens with me. I would like to know if there is a more practical way to do this. Also, if I am not mistaken, the outputs obtained by splitting the beam need to be combined later. It would be nice if you could go for an arrangement that could prevent this, that is, define a cantilever on the partial edge without splitting the beams. Respects.
"cihanonarici":x1qjvvwb" said:
Good afternoon.As far as I understand, the definitions of the type of balcony I have sent in the attachment cannot be defined without splitting the beams yet, it is stated in the program book that I need to use the divide by intersection option, but this icon cannot be selected in the slab description toolbar because it is inactive, so it cannot be selected manually and then split the beams later. I need to set up the system, at least that's what happens to me. I would like to know if there is a more practical way to do this. Also, if I am not mistaken, the outputs obtained by dividing the beams need to be combined later. If I am not mistaken, it would be nice if you go for an arrangement that can prevent this, that is, define a cantilever on the partial edge without dividing the beams. Regards.
Hello, In the program, the slab edges automatically divide the beams to which they are connected. For this, it is sufficient to have the line divide by intersections active in the beam auxiliary toolbar.
Sorry my mistake, divide by intersections was already clear, but since I defined my slab edges up to the beam boundary, not the axle, it's not split, thanks.
