Problem with 4K resolution
muratozev
I'm using idecad on 4K resolution computers and I'm having idaced compatibility problems. Icons in İdecad are very small. Is there a setting for this? İdecad is too bad to be used. Is Idecad still not compatible with 4K screens?
"muratozev":wx1n7ga0" said:
I use idecad on 4K resolution computers and I have idaced compatibility problems. The icons in idecad are too small, is there a setting for this? İdecad is too bad to be used. Is it still not compatible with idecad 4K screens?
Hello, You can choose large icons in the Classic menu. You can do the operation in the Options section from Customize. For the ribbon menu, the request to add icon options to the program is an issue in our work list. Thank you for your notification.
