Problem occurs when I get the basic app plan
arembero
Hello, take it easy, I ran into a problem, I couldn't fix it, I'm waiting for your help. As seen in the picture, when I get the basic application plan, irons, scales, borders and texts, cross-section images, nothing. .html]http://s9.dosya.tc/server/4tv346/Untitled.png.html[/url]
"arembero":i0v2lm0i" said:
Hello, I've come across a problem, I couldn't fix it, I'm waiting for your help, as seen in the picture, when I get the basic application plan, the irons, gauges, borders and text cross-section images are nothing, I wonder what is the reason for this
Hello, Could you attach the project file?
In the project, the standard layer is closed and locked. Switch to the basement window and enter the Layer settings dialog. Open and unlock the standard layer. Check the "Apply to all Drawings" option, click OK and import the Basic application plan drawing. Note: When analyzing your project, the system gives a warning that it cannot be resolved. The beams defined on the eaves elevation ceiling stay in the air. No columns are defined in this floor. Also "beam tile edge overlaps" etc in geometry control. geometric warnings available.... Good work
