Problem in Beam Joint
ogzhnsfgl
Hello, I am a new ideCAD user. I'm having a weird problem with drawing beams as you can see in the attachment. The program automatically creates the region I marked in red. I couldn't find where I went wrong. I am waiting for your help.
Hi, There is probably a very small angle difference between the connecting slab edge and the beam in the area you marked. Change the trim algorithm of the left end of the beam with the "Object Trim Method" command. Good work
