Probably typical beam continuity error
29602526732
hello, in my attached project, I am getting "probably typical beam continuity error" in geometric error. Since my floors are not at the same speed, I cannot fix this error no matter what I do. I will be glad if you help me. good work.
Hello, - If the cassette flooring teeth will be applied in this way, ignore the warning. -One account beam can be defined for both directions in cassette slabs. If the cassette slab is adjacent to more than one slab, ignore the typical tooth warning again. (For example, KD5 slab is continuous with both KD10 and KD11.) For cassette drawings, you can first define the calculation beam to ensure continuity with the 1st slab and get a drawing. Then you can arrange the calculation beams to ensure continuity with the 2nd floor and get a drawing. Calculation beams do not affect the overall structural analysis. - It is not appropriate to open a gap in cassette flooring to cut the teeth. These gaps are not taken into account in tooth calculations. Good work
