Hello, If you make the program name the same as the previous version, your shortcuts will also appear in the new version. Program name -> ideCAD_Statik_7_x64.exe should always be used the same... When you update with the installation program, since the program name is left the same, if you haven't changed the name, you should be able to see the shortcuts and toolbars exactly in the new version.
