pool and concierge room and engine room together
insburak355
hello, in my project I have a makna flat and a janitor's flat next to the pool. I can't add any columns when I solve the pool. thank you
Let me make a correction. I will solve the doorman's apartment as a separate project. My problem is how do I solve the engine room with its columns and the pool, because it has to be a single reinforced concrete project. apartment and pool
In your architecture, the views are missing, where is the pool, where is the indoor pool or where is the shop? good work
"insburak355":meu0fdw7" said:
let me make a correction, I will solve the concierge's apartment as a separate project, my problem is how to solve the engine room with its columns together with the pool because it has to be a single reinforced concrete project, the machine room and the pool
Hello, The pool object is the other structure in the program. It cannot be solved together with its elements.To solve the pool together with the engine room, you can model the system with beamless raft, panel and column objects and affect the loads consisting of soil and water on the panels.You can get information about load definition from the links below. /forum/viewtopic.php?f=21&t=1582[/url]
pool open pool, separating the janitor's room and the shop with a joint, I will solve it as a separate project. The issue I am having trouble with is that there is a machine room next to the pool and it has a combined architecture with the pool, which will be built between -2.25 and 0.00, naturally, while analyzing the pool, how do I make the columns of the engine room efficient and how do they both together? I will analyze. What should I do if I cannot analyze both together because the engine room and pool will be a single project in the project I will deliver.
You can reflect the pool loads to your project by applying the load definition processes from the links sent by Mr. Levent. So you do not need to enter the pool, you can only reflect the load of the pool from the unit volume weight of the water to the curtains and solve your system in a normal way
