As it is said, I turn the closed area into a pool, then I have the analysis done and then I enter the reinforcement spacing and diameter in as1 or as2, the place that turns white does not happen at all.
Re: pool analysis-?equipment? The document you are looking at may not be compatible (up-to-date) with the version you are using. The explanation in the current help information of Ver 7.022 is as in the picture.
