Mr. Fixed, First of all, I wish you a happy new year... I hope that the subject we discuss here is not limited to Ide's solutions and approaches, let's continue to discuss engineering... Now, as you said, the rate of 1/5 compared to others is more According to another, 1/4 ratio may be considered close, maybe you are right. It is a relative situation after all... However, I think there is a gap in the boundaries of whether a vertical bearing element is a curtain or a column... Namely; for columns defined as bxh>=25x30... (b: short side, h: long side) for walls, defined as L/b>=7... for columns the ratio of long side to short side (h/ b) Is there a maximum limit value in the regulations? (I couldn't find it, if anyone knows, please help us, I would be grateful if they could tell us which regulation it is in...) However, there is a recommended value for this limit. Some of our professors say that this value (h/b) should not exceed 3 ~ 3.5... the main question arises here by itself... how do we approach the elements above this limit value but also below the 1/7 ratio? Curtain pattern, ratio less than 1/7. If you look at it as a column, the h/b ratio is greater than 3.5... (weak column, buckling problem, slenderness... etc.) Elements whose contribution to the limitation of the relative storey drifts cannot be neglected can be said to be almost as effective as the curtain... I think that there is a gap. In my opinion, the regulation approaches with very sharp rules and a straight (Aristotelian Logic) logic "either you have a curtain or a column"... well, is there any in-between? can't it? In my opinion, approaching the event with Fuzzy Logic will lead to more flexible solutions. For example, choosing the Ductility level as Karma; While it limits the relative storey drifts in the lower floors in curtain walled structures, these offsets increase as one goes to the upper floors... In framed structures; While the relative displacements on the lower floors are very high, these displacements towards the upper floors decrease. This approach underlies the fact that the mixed system is both an economical and flexible solution. We do not limit the event with sharp lines, we do not say High or Normal ductile. We said; Let my high ductile shears work on the lower floors, limit the displacements, on the upper floors my curtains are weak against the displacements, so Normal ductile columns should come into play, limit the offsets and the construction should be flexible and economical... I think that such an approach should be added to the regulations regarding the elements mentioned. Thank you for your patience... Best regards...
