Polygon colon
omurgune
Good day, I am in the process of converting from a continuous line to a polygon column in some columns. For example, the column is 30 cm high, one side is 60 and the other is 59, but it appears as 60 in the column information, is it a problem? I also made the 72 cm column this way, but it looks 60*30. is this a normal thing?
"omurgune":2irb5w0s" said:
good day, I am in the process of converting from a continuous line to a polygon column in some columns. For example, one side of the column is 30 cm high, 60 on the other, 59 etc. But in the column information, it shows 60. Is there a problem with this. I did it like this, but it shows 60*30. Is this a normal thing?
Hello, The size information that appears when you hover over the column is for rectangular columns. You can see the size information of the polygon column in the column report. Good work
