Sorry for my ignorance, but I don't understand how to create it within the panel"insmuh_gk":2v8qp8nf" said:In that case, you create the column region within the panel, anyway the program will create the header region depending on the panel size.
Hi, Polygon column is a rod object. No beam or slab edge can be inserted between it. You can enter elevator curtains as panel objects and model them as shells."MAHAL00":2cktpne8" said:Hi, I need to close the empty end of the polygon column defined in the project I sent the attached file (I sent the relevant part) with the slab edge, leave the inside of the polygon column empty and assign a slab to the other part, but I can't get it done. I wanted to draw a beam. I can't change the shape of the Polygon column.
Then you can enter the system without the column object as in the sample project."MAHAL00":2cktpne8" said:Thanks for your attention, I thought too, but what if the section you defined as a column was 25*25, there are places like that then the column dimensions would not comply with the regulation
