Hi, According to the analysis results, when I have the basement floor column application plan drawn by the program in my project, which has no errors, an interesting drawing occurs in the curtain detail as in the screenshot below. The problem in the drawing is due to the small angle between the panels P8-P9. You can arrange the drawings using 2 dimensions. Or; You can draw a single piece panel between S06-S09. -You can define a column object between P08-P09. -Also, some columns are too close to each other Reinforcement details in 1/50-120 scale can overlap each other. I recommend getting a column application plan by checking "always detail outside in application" from panel and column properties and "Draw detail block" options in panel properties.
"ftthylmz":1rnhfrab" said:
Another If the problem is, the empty windows that I have opened on the curtains appear in the basement column application drawing detail. Greek equipment is not visible. What should I do so that the longitudinal reinforcements are visible.(
In case there is a gap in the panel, the reinforcements in the gap area are not visible in the application. It is visible in the curtain details. Good work
