Hello Emre, Program to print this control in the report TotalAg/TotalAp>= It checks whether the ratio of 0.002 is provided. If this ratio is met, the check is performed. Put another 300 cm long curtain, for example, in the x-axis direction, on the sample project you have added. This check will be done."EmreT":10934ark" said:Street ratio control (TDY 2018 item 7.6.1.3) is not performed in my model, which consists of only curtains.The relevant model is attached.
We have received our notes on the situation, Mr. Emre. Thank you for the notification. Good work"EmreT":2k9rblno" said:Thanks for the reply Mr. Levent.Only in the first case (2 pieces of 25x300cm curtains in the X direction) the curtain area is 1.5m2 and the ratio is 0.0035 (1.5 / 430.5 ) and it provides the ratio.
