pillar
idecad_kkk
I don't want to use pillars on beams and flooring, but the program determines project reinforcements with piles. How can I prevent this? I would be very happy if you reply. Thank you.
For slabs, if you press the "edit slab calculation axis" button from the slab toolbar, you can set the reinforcement options for the relevant calculation axis. For beams, if you select the relevant beam and enter the properties command from the menu that opens when you right-click, enter the pile/total min and max values to zero on the static/reinforced concrete page, the program designs the beam without pile. (These parameters determine how much reinforcement will be bent as a ratio in the beam span). In the upcoming version (6.01 beta2), we have added a "pileless design" box to the beam settings to make it easier to use.
