Hello, I'm a bit lacking in this regard as I haven't solved a project with a pile raft foundation against many previous projects. Without further ado, how can I calculate and obtain the following parameters for data entry into IdeCAD. The geology firm that made the ground survey said that it is not our job to give these parameters and they went out of business. They've even just heard of one. - Vertical spring factor (kv) (t/m3) - Adhesion factor - Undrained shear resistance (t/m2) The data I have; - Soil type: The upper levels are large and small, the rock quality is low-medium strength, the rock quality rises towards the bottom, the unit with high strength limestone features - Soil safe bearing capacity: qem = 2.00 kg/cm2 - Soil group: B - Soil class: Z2 - Ground bearing coefficient ks: 10000 t/m3 - Internal friction angle (fi) = 35 degrees - Cohesion C = 3 kg/cm2 Thank you to everyone who has already guided me and have a good day.
                     German
 German  French
 French  Spanish
 Spanish  Portuguese
 Portuguese  Italian
 Italian  Arabic
 Arabic  Russian
 Russian  Japanese
 Japanese  Turkish
 Turkish
