Pile miter problem
mimarss
First of all, have a good day. In the project I am preparing, the square length of the upholstery pillars shows as 50 cm in the mold plan, no matter what I did, I could not reduce it. When I examined the other projects, these lengths were solved as about 15 cm. I know the bond length is 45@, I wonder if there is a problem with the settings in my project or is the given miter size appropriate. The project is attached, I am waiting for your help.
"mimarss":1puc7rkl" said:
First of all, have a good day. In the project I am preparing, the miter length on the upholstery pillars is shown as 50 cm in the mold plan, no matter what I did, I couldn't reduce it. Is there a problem with the settings in my project or is the given miter size appropriate. The project is attached. I am waiting for your help. url]
Hello, ideCAD calculates the slab reinforcement miter length by deducting the rust margins (max 50 cm) from the depth of the beam. Your 77 cm beams create a 50 cm square due to this situation. You can also examine this situation in the TS500 9.1 Rebar Clamping section. .
Thank you for your interest, Mr. IT GIVES MITER LENGTH OF 44 CM IN 50 BEAMS, 50 CM IN 60 BEAMS AND 50 CM MIRROR LENGTH IN 77 BEAM AND WHEN I REVIEW OTHER PROJECTS, I BELIEVE THAT THEY ARE DRAWN WITH DIFFERENT PROGRAMS. THEY GIVE A MIRROR LENGTH OF 15 CM. THAT IS THE REASON. THE PROBLEM IS NOT MAKING EXCESS TONS, BUT NOT MAKING AN APPLICATION ERRORS.
