Pile foundation must be defined in beamless raft system
mkrts88
Is such a definition appropriate? the raft will not be under the foundation, but before the building is started.
I guess piles will be made as a retaining. It is wrong to solve pile foundations that have no connection with the building in the same system as the building. You need to solve the building separately. Is it the subject of ideStatk in pile foundations to be made as retaining? The room is another matter.
"proisa":11j12ie2" said:
I think piles will be made as retaining. It is wrong to solve such pile foundations that have no connection with the building in the same system as the building. You have to solve the building separately. Is it the subject of ideStatk for pile foundations to be made as retaining? issue.
I did it this way to determine the geometry that will need to be solved separately.
