Pier Macro
zynpatmc
Hello. I'm trying to solve the scaffolding macro in IdeCAD. I have a problem that I can't find the dock when I close and open it even though I save it. It's either deleted or I can't switch to dock mode. I tried clicking the dock again and switching back to the dock mode but in vain all the deleted docks :/
Friends, some sections are not in the library of idecadin. For example, I don't want to use CHS42*2.5 for diagonals, but it says no cross section found. How can I upload a new section?
"zynpatmc":2j4n7d00" said:
Friends, some sections are not available in idecadin library. For example, I don't want to use CHS42*2.5 for cross sections, but it says section not found. How can I upload a new section?
Hello, Sections in Structure Tree to define sections Click on the line, right-click, click "Add Section" from the menu that opens. In the dialog that opens, select steel material from the Material section. You can click the Load from Archive line and select the section you want from the section library that opens.
Thank you very much for your interest. But the steel part does not open :/ I am currently using the demo of 8, but do you think it might be related to the demo?
"zynpatmc":3ahxf289" said:
Thank you very much for your attention, but the steel part does not open :/ I am currently using the demo of 8, but do you think it might be related to the demo?
url]
"zynpatmc":2azvzhgi" said:
Isn't this the place you said? When I say add a new section from here, the menu I throw in the previous picture
When you say Add New Section, the menu you added does not appear, the section settings window appears. You can load the section you want from the section library of ideCAD by clicking ".
