Piece by piece the beam is unraveling
ysfdmn94
Hello friends, when the beams are drawn and analyzed as in the figure, these beams are shown as 3 separate parts in the beam details. Additions do not match. What can I do to fix this problem. When I look at the details I want to see them as a single beam. Thanks in advance.
Hello, There may be small angle differences in the beams you describe. Enter the Reinforced Concrete menu / Parameters / General reinforced concrete parameters. In the parameter "Continuously accept beams with small angle difference", enter an angle of up to 30 degrees. Analyze again. In this way, you can ensure beam continuity in small angle differences. If the problem is not fixed, add your project.
The choice regarding continuity adequacy is up to you. Yasin said that as an example. If you think that more of it will not constitute continuity from the angle you have given and that the reinforcements should not be extended, it is 5, 10.
