Hi, As you can see in the attached picture, there is a constant error in the length of the foundation L. The length of the foundation beam is 1150 and the thickness is 50 cm. In this case, when the margin of 1150 -10 cm is deducted, it should be 1140, instead of 1144.[ /quote] Hello, We have taken note of your statement about the length of the continuous foundation reinforcement. At this stage, I can suggest that you make the column concrete cover the same as the continuous foundation concrete cover and take the continuous foundation opening. (After you get the continuous foundation drawings, you can restore the column concrete cover to its original value.) [quote ="muratkanici":cmu3hhrg"]A second problem is that it does not divide the reinforcements that pass 1200 cm in the foundations. Good work.
