your project has reached me, but I could not open it because it is a demo version"blackline":24kqey93" said:hello, when I make the slab without a beam with a perimeter beam, I get the error 'the slab thickness does not meet the required requirement'. Even though I increase the slab thickness, I get this warning over and over. good work.
yes, there is cork flooring analysis..."fixed":hugyrn1x" said:hi friends, can ide solve cork flooring? I was going to write to the forum to see if there is any development on this subject. Is there a development, am I not aware of it?
Isn't it necessary to check for punching for middle columns? I could not access the information with the stapling control in the reports, how can we control them?"mhanifiata":2f4r2g5k" said:I opened your project by installing the demo version. I just edited the part about the beamless flooring. The file is attached... your maximum axis distance is 5 meters, accordingly I set the slab thickness control to 5 meters. the problem is fixed... but general As a result, you need to connect the columns to each other with fictitious beams for floor displacements, rotations, etc. for earthquake investigations, otherwise, these calculations cannot be made exactly, especially in high buildings...
In such systems, you need to define an additional column header for punching control. under the column menu... when you define the headings, you will see the stapling checks done in the tiling report..."blackline":2zj3sp1q" said:Isn't it necessary to check the punching for the middle columns? In case of perimeter beams in non-beam slabs, I could not access the information with the punching control in the reports, how can we check them?"mhanifiata":2zj3sp1q" said:I opened your project by installing the demo version. I just edited the part about tiling without beams. The file is attached. Your maximum axis distance is 5 meters. Accordingly, I adjusted the slab thickness control to 5 meters. the problem has been fixed... but in general, you need to connect the columns to each other with fictitious beams and untie them for floor drifts, rotations etc. otherwise, these calculations cannot be made exactly, especially in high buildings...
For example, how do you make the cork flooring solution of a 10-storey building? How do you define fictitious beams? How do you evaluate the floor drift results? etc. etc."mhanifiata":3sl3ph3b" said:yes, there is a cork flooring analysis..."fixed":3sl3ph3b" said:hi friends, can ide solve cork flooring? I was going to write to the forum to see if there is any development on this issue. There is a development, am I not aware of it?
greetings... at the moment we have a 16-storey building... its design is finished and it is in the technical drawings stage... I am giving the design of this building in order... first of all, it is necessary to create 2 building models... .model: If there are perimeter beams, the outer frame is completed with the perimeter beams, if not, the static slab edge and slab boundaries are drawn. slab placement is done. The span value in the reinforced concrete calculation axis is changed to have the slab thickness check according to the largest column span. He's making a raking account, it needs to be fixed On the inside columns, column heads are defined at floor height (or higher if necessary). this is a must for the punching calculation... this is how the system is completed and analysis is done. The tiling report is examined, if the height is sufficient and there is no problem in other element dimensions, save as is passed to the other system (2nd model). 2. model: model to be created for earthquake calculation. In this model, the columns are connected with beam elements at floor height and at the width recommended for support bands at TS500. meanwhile, the floor height had been calculated beforehand. in this way, floors are added to the system and analysis is made. this analysis is only used to determine earthquake parameters. General earthquake reports can be obtained from here. Can be combined with other system's reports. If there is no problem in this system, the drawings of both systems are combined and used. flooring reinforcements must be adjusted as bottom-top. In accordance with the principle that the beam height cannot be less than 3 times the floor height in TS500, it is necessary to arrange the lower and upper reinforcement instead of assuming that there are beams and there will be tension on the support at the top. general reports should be taken from the 1st model."constant":2u5t0okg" said:For example, how do you make the cork flooring solution of a 10-storey building? How do you define the fictitious beams? How do you evaluate the floor drift results? etc. etc. etc."mhanifiata":2u5t0okg" said:yes, there is a cork flooring analysis..."constant":2u5t0okg" said:hi friends, can you solve a cork floor? There is a development, am I not aware of it?
Greetings... One of the purposes of the forum is to guide the developers by bringing up such shortcomings. But what I want you to know is this: software is just a tool. They are not design geniuses. As a result, when we look at the technical books, the approach methods and acceptances are clearly seen. The software does what a calculator does, with advanced and graphical support. I've been following ide since taaa 98. and I have been using it de facto since 2003. The point we've reached is literally unbelievable. We didn't even dream of beamless slab analyzes then, which we don't like now. even in this forum, a friend had published the catalog pictures of the past. If possible, it would be great if ide officials would share those old pictures here... If you think what should happen with beamless flooring, write it here.... specify the deficiencies. I know that every subject written is noted somewhere and eventually gets a response..."fixed":3360lx6e" said:Thanks for what you wrote above, but we don't solve cork flooring in this way, it is forced cork flooring, but here it comes out as you mentioned. I mean cork flooring can be solved without the need to create 2 separate models, after creating a system and calculating earthquake loads able to define fictitious beams in their own way, calculate the translations correctly etc. etc. The shape you mention can of course be a situation but it is so open to error and in my opinion it is a wrong method. Think about it, you enter all the calculation openings one by one, you create a system, then you create another system and define the beams. Nobody has this much time. No. We talked about this issue with friends from ide 2 or 3 years ago and it was going to be developed, but there was still no development in this regard. The developments are definitely admirable, because ide has come to the farthest point from the back. It is an issue that has been missing for me and needs to be done already. cork flooring. Maybe the forum title is not appropriate on a subject I see, but these are the expansions of U, L etc type curtains. I still spend a lot of time on drawings and correcting such curtains.
