[email protected]
dear forum officials, my question is from the municipality, a building with the existing basement-ground and 1st normal floor will be designed as masonry and when it is covered with a steel roof, the performance analysis of the building is requested. The loads determined by the steel roof analysis will be applied to the last floor columns. Will the roof load be defined by entering all floors, including the foundation, or will it be sufficient to transfer the roof load by entering the column beam and floor of the last floor? Thank you in advance for your interest. NOTE: It will not be possible to adjust the amount of iron in the existing static project of the building for 10 years and to save the columns.
