PERFORMANCE ANALYSIS
kasky
reinforced concrete analysis We can do it, but we can't get a performance analysis. It warns that there should be at least one column on each floor. I would appreciate your help.
"kasky":333szuxq" said:
we can do reinforced concrete analysis, but we can't get performance analysis. It warns that there should be at least one column on each floor. I would appreciate your help if you could help
In the project, all columns are defined freely on the attic floor. Select all columns to solve the problem. Change Click on /Object Edit/Column/Top Free Columns In the dialog that opens, uncheck -Let the upper nodes of the selected columns be independent of the floor- and click OK.Do analysis and performance analysis respectively.
