Performance analysis 3D visual results
Mesut Turan
Take it easy Hello; 1- ) Which elements of the structure cannot be displayed in which damage area in the display section of the performance results after the thrust analysis, can you help me? 2-) Circuit Elements are not visible on the 3d screen. 3-) In the linear performance analysis calculation report; At the performance level of preventing migration, the most difficult item to provide is ''All of the other carrier elements must be in a limited, obvious or advanced damage area'' item. Examining the whole report one by one is tiring to select the elements in the collapse region. It would be really nice if the elements in the collapse region were determined in the form of a table. As far as I know, the regulation does not allow brittle elements regardless of the performance of the building, so it would be nice if only the brittle elements were specified in a table. We do not use the performance analysis results only to strengthen the reinforced concrete jacket in the program. I want to use the results of the idecad program for the reinforcement made with Fibrous Polymer, Steel, but it seems useless to me. 4-) When viewing the Linear Performance analysis results, I can't see either brittle or damage levels. All the elements appear as gray. 5-) When will the work for the Push Analysis report be concluded. Good work. Best regards
Hi, 1-) Pushover analysis is not available at the moment. 3-) I agree with listing the brittle elements and listing the elements in GB. Here I also stated:
Fibrous polymer or it does not have the feature of strengthening with steel anyway. What do you mean by using results?
After performing performance analysis, there is a result display section, but it cannot be displayed? all elements appear gray ? Performance analysis results need to be presented to the user interrupt force. The brittle column elements that do not provide brittle columns should be listed separately with their names, so that in order to observe the results more easily while performing the reinforcement project as a result of the performance analysis, the whole event starts after the performance analysis.
1. We are still working on the pushover analysis. 2. The performance analysis results display in the visualization dialog was prepared for TBDY 2007. Its use for TBDY 2018 is currently not valid. 3. In the report program, click on the Change/Find line after receiving the performance analysis report. Then you can see the elements in the collapse region in order by typing GB for the failure region elements and clicking Next. Similarly, you can search for other terms. You can also see the Brittle elements in order by pressing the F6 key. There is no possibility of reinforcement with steel elements or fibrous polymers in the program. 4. The display of performance analysis results in the visualization dialog was prepared for TBDY 2007. Its use is not valid for TBDY 2018. 5. Our work continues and we cannot give a date. The previously given dates had to be changed with the intervention of other works. Good work
