When a project modeled in ide 5 is opened with ide 6, some column-beam connections do not hold the nodes. For example, when I open the attached project in ide 5, there is no problem, but when I open it with ide 6, the K23 beam does not hold the column on the 3rd floor.
Log in or register now.
(I tried to load the project directly from the forum, there was a problem I had to use rapid) is a separate question... when we enter the project, it perceives that floor as a normal floor according to earthquake regulations and makes irregularity investigations. Since the area used on that floor is very small compared to the normal floor, results such as relative floor drifts and soft floors occur. I don't know if the regulation includes the basement and roof in irregularity controls, but I ask you to comment on this... and when a solution is made by accepting more than one rigid diaphragm on the same floor, in some of these diaphragms; B2 irregularity, story drifts and second order effects exceed the maximum limit. When we want to solve this solid as a single diaphragm, this problem does not occur...
