AFTER I EXPORT THE PROJECT I DRAWN TO DWG, THE NUMBER OF IRON AND LENGTH COLOR WHICH IS YELLOW IN THE IDE FORMAT IS RED. BECAUSE I SET IT AS RED REINFORCEMENT, THE TEXT THAT SHOULD BE 0.2 WILL BE AT 0.5 THICKNESS. IF THERE IS ANY OTHER WAY TO FIX IT ONE BY ONE IN AUTO CAD, I WILL REQUEST YOU TO HELP. SUCH IN ALL DETAILED EXPANSIONS. WHEN IT SHOULD BE IN THE NAME OF THE COLUMN BEAM, IT IS TRANSFERRED TO DWG IN A DIFFERENT COLOR. I CANNOT CONVERT THE COLOR OF THE LINE ON THE MEASUREMENT FROM RED TO ANOTHER COLOR. ALSO, I CANNOT UNDERSTAND THE COLOR IDENTIFICATION EVENT SEPARATELY FOR EACH DETAIL EXPANSION WHILE BUYING THE EXPANSIONS. WASTE OF TIME. I'M USING A BLACK SCREEN WHEN I LOOK AT THE BEAM OPENINGS FROM THE REINFORCED CONCRETE MENU, THE WHITE SCREEN IS COMING. DUE TO THE COLOR OF TEXT THAT IS YELLOW, THE COLORS OF THE WRITING ARE NOT READ.
