Pastel settings
Click on Settings/Materials. Double-click the material you used for the tile. In the dialog that opens, mark the "Transparency" line and enter the ratio in the "value" line.
There may be a problem with your project. For example, does the same problem occur when you open a project with a template project? If not, you can add the project. If so, if you reach us from our Bursa office, we can look at what the problem is and its solution with remote access.
