Partial stiffness in short beams
cakilomer
I have short beams in my 10 storey project and no matter what I do it doesn't save. Can I define partial rigidity for them? If I define it, what should these values be? I wish everyone good work
There is a post on the forum about this, but I don't know if it will be useful for you, can an evaluation be made with your situation, let's see if you do not mind adding the prone, can you add it?
Thank you for your attention, I looked at the same topic, but unfortunately there was no solution, I learned that I need to get information from the necessary literature. The project is very big, but I will have to produce other solutions between the beams I mentioned and the polygon column and the curtain. I wish you good work
