In such multi-panel combinations, in version 5, the panels were considered as the distance of the two points where they were entered. Now, not the clicked point, but the middle of it is taken into consideration, the merging share of the element in the other direction is also considered. For example, you have entered two panels, one horizontal and the other 4 meters vertical, defined from the top. In 5, the panels were drawn as 4 meters by 4 meters based on the click points. However, there is a common ground. In 6, the centers of gravity of the panels are taken into account. Thus, the common areas are not detailed twice. It is healthier to combine the reinforcements in such panels anyway. In the future, instead of equipping them separately in this way, there will be an arrangement in the program that will equip them all at once. Good work...
