Thank you aozhan90. I have solved the problem. For including the intermediate landing floors in the rigid diaphragm there was a problem."aozhan90":2kz6284q" said:my dear ryıldız hello, when you remove the fixation on the curtains P01 and P02 and solve the system semi-rigid, the slip problem is fixed. Good work
1-It did not improve even when the panel was fixed and analyzed 2-Because the roof space is used, live load according to the intended use I can't reduce it 3-I couldn't add symmetrical curtains because there are closed overhangs on three sides of the building. I will review it again. 4-It has been corrected. 5-GI, there is a gap on the floor, not stairs between 1-3. 6-Stairs are given. They are not included in the system. 7- stairs not included in the system, only loads were given. 8- It's good that you said that. I missed it. Architecturally, there is no obstacle. Thank you for your interest."unver":1bjn94ei" said:Sn ryildiz My Suggestions 1- Remove floor, beam, column, panel fixing, 2- You can reduce the 2nd floor ceiling live loads (roof), 3- It would be better if you add curtains to the system in both directions, 4 - Correct the errors in the columns (B), 5- If GI is a ladder between 1-3, the modeling is incorrect (not as flooring), it should be corrected, 6- In other ladders, the support conditions should be given, 7- To calculate together with the ladders, semi-rigid diaphragm solution should be done 8- The beam between S08 and S09 is too short, the columns can be shifted to the left S08, S09 to the right. Take it easy Ünver ÖZCAN
