Panel dimensions and expansions..
Bolvadinim
Hello, While the dimension text of the panels (curtains) defined between the two columns is taken into account in the floor plans from axis to axis, the measurements are given according to the clear span between the two columns in the details. While this situation causes confusion, it also leads to waste of time with unnecessary measurement corrections. The end zone on the curtains is created by the program according to the criteria, if necessary. As users, we are not involved in how much the curtain end zone will be created (stirrup type design). We can solve the problem by defining the column, changing the end zone conditions in the curtain parameters, and defining the curtain between the columns. In addition, another problem related to the drawings is the following: The expansions of the elevator curtains are not drawn in the column application plan. bond They are drawn independently..However, they should be drawn together..
