P05 and basement curtains connected to it do not connect properly
evanes07
Have a nice day; In my project, P05 curtain on the right side and the basement curtains connected to it are not connected properly, the curtain shows incorrectly when I take the detail drawing, I wonder what is the problem
Re: Curtain drawing error is urgent.. Also, I tried to draw the staircase as I always draw with the route command, I drew the first staircase area, I said create a new staircase, when I mark the outer boundary of the staircase and the exit line, it creates a landing, I cannot select the staircase? Can you see what is wrong with this?
Re: Curtain drawing error urgent.. Hello My suggestions; --Since you didn't create the raft foundation to include S35-S37, it gave a stapling error, --Short objects were deleted, --The 0.5 t/m2 live load on the beams connected to the columns at the front was corrected by taking zero. (1st basement ceiling) Now it doesn't give an error. The corrected project is attached. --Some beams have a live load of 0.5 t/m2? --Remove live loads on beams, --4. and you can reduce the moving loads on the 3rd floor (roof) and remove the wall loads, --S23 column is cantilevered inside, this is not a desired situation, --Take the ladder loads, --Fix the ladder support conditions, Take it easy. Unver ÖZCAN
"unver":3ul08lg6" said:
Hi My Suggestions; --Since you did not create the raft base to include S35-S37, it gave a punching error, --Short objects were deleted, --The live load of 0.5 t/m2 on the beams connected to the columns at the front has been corrected by taking zero (1st basement ceiling) Now it does not give an error. The corrected project is attached. --There is a live load of 0.5 t/m2 on some beams? -Live loads on the beams lift, -You can reduce the live loads on the 4th and 3rd floors (roof), you can remove the wall loads, --S23 column is cantilevered inside, this is not a desired situation, --Take the ladder loads, --Fix the ladder support conditions, Take it easy. Ünver ÖZCAN
Thank you for the answers, Mr. Ünver; I made the live loads of the basement beams 0.5 t/m2 because the ground floor will be a parking lot, is it wrong? I arranged the beam loads of the 3rd and 4th floors. Also, the main thing I asked was P05 per The desi is 175/25 but when you draw the basement curtains, it shows as 209/25. Also, P05 drawing looks wrong in the curtain details, have you looked at it?
