Re: DRAWINGS Hello, Just press the M key on the keyboard and click on the text to move it to the desired location. Unlike the normal move command, you can quickly move the texts and sub-blocks in the block without exploding. Here's how fast move works. For example, by clicking on a stirrup in the column detail, you can move the stirrup with its texts without exploding. While editing the mold plan; When you click on a pillar accessory, the pillar is moved along with its texts. If you click on the text on the pile, only the reinforcement text will be moved. Only if the M key is "Quick move" M + Spacebar is the shortcut for the Move command.
