Caner Kıvcı
Hello, good work. I've noticed in a few projects I've done recently, there is a situation that I fix manually. For example, our lowest mass level is -0.48. A building without basement and its basement level is +1.20. When you make a solution without defining the basement curtains, it starts the overlapping 184 cm above the foundation. This means overlapping at +1.36 elevations. For the ground floor, it is as if it were in the old regulation, and overlapping is done at the floor level. I enter the system and solve the sub-basement curtains, and it does the overlapping at the same place. I have to divide the 298 cm, which is the floor height after the basement, by 3 and add it to the +1.20 level, and I arrange the column overlaps there by hand. Is there a different way to do this?
