Over-Reinforcement Problem in Walls and Columns
huseyinakkus56
Hello.. On the curtains, there are pale reinforcement values such as 66 fi 6000; even though I selected the reinforcement diameter as only 12mm from the curtain settings. What do you think could be the reason? Do I have to manually fix them one by one; Can you help me if there is another way?
Hi, the reinforcement diameter may not be selected for the vertical end zone in the Shear Reinforcement Selection dialog. If the problem is not fixed, if you attach the project file, we will review it. Good work
