oval axis drawing
mühendix
IN THE ARCHITECTURAL PROJECT, AXLE DRAWINGS ARE INCLINED. I TRIED TO PUT A AXLE IN STATIC BUT I DID NOT KNOW IF I ENTERED CORRECTLY. I CANNOT CARRY THE INCLINED AXLES OUTSIDE THE CONTOUR AND I CANNOT MAKE THE MEASUREMENT OF THE INCLINED AXLES. I WOULD LIKE TO HELP YOU WITH THESE ISSUES. THANK YOU FROM NOW. THE PROJECT IS ATTACHED.
Re: OVAL AXLE DRAWING Arc axes stay between the points they are drawn in the program. They are not extended to the axle limits. It can be seen that this option is inactive when the properties of the spring axle are entered. If you want the axis names (axle labels) to be when drawing the arc axis, you can click these points to start and end when defining the arc axis. Good work
