output properties
endazeyar
It prints the project from the end when outputting in 5 versions of ide. It would be very good if an arrangement was made in 6 versions of the ide in such a way that it would regenerate the project.
Hi, when printing from ideCADStatic or ideCAD Architectural media, output is taken using the Windows printer drivers available on your computer. You can print out the drawing by using the symmetry (mirror) setting in the printer or Plotter settings you are using, by changing the rotation settings and turning your project 90-180 degrees. Good luck with. Good work.
